Forums >> Revit Systems >> Technical Support >> Duct Systems.
Mon, Aug 5, 2013 at 6:18:04 AM | Duct Systems.
N1CKREV
Hi I am working on revit 2013 MEP. I have linked an architects file into my project file and I am modeling duct work and pipework. This is going fine, but when I select duct or associated fittings the fitting moves? Is this a co-ordinates problem?
Mon, Aug 5, 2013 at 7:48:16 AM | Duct Systems.
Turn off press & drag - bottom right corner.  If that doesn't fix your problem - read this.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14997251&linkID=9243099
Revit Systems duct connections
Thu, Jun 11, 2009 at 9:32:41 AM
Revit MEP 2010 Duct System Colors
Tue, May 18, 2010 at 6:04:49 PM
Duct System problem
Fri, Jan 11, 2013 at 8:05:19 AM
Flat Oval High Pressure Duct???
Sat, Oct 17, 2009 at 7:48:59 AM
Return Air systems help? Please
Tue, Feb 9, 2010 at 11:42:41 AM
Page generation time: 0.5151
