Forums >> Revit Building >> Technical Support >> moving walls
Thu, Aug 1, 2013 at 8:26:58 PM | moving walls
rgaaia
2014. having difficulty moving walls horizontally to match other wall's vertical face that are above or below. they seem to be locked but cant find a way to unlock. also is there a way to get the unlock indicator without having to move them first?
Fri, Aug 2, 2013 at 7:40:51 AM | moving walls
Whenever you pick an object, you can look at the menu bar and see if the unpin or pin is available to you.
To clear a lock on items that are locked by dimension (which may have been deleted or in another view) can be re-dimensioned, locked, then un-locked.
Alignment locks show up when the item is picked.
For moving a wall that is joined to a wall above or below, it is sometimes best to pick the unjoin button.  Be aware that this will delete all dimensions to this wall or any associated tags.
Tue, Aug 6, 2013 at 8:54:03 PM | moving walls
rgaaia
thanks this is very helpful!
MOVING AND ALIGNING WALLS
Sat, Mar 10, 2012 at 5:57:39 AM
Walls moving/ disappearing ?!
Wed, Nov 2, 2011 at 2:37:01 PM
13
Electrical components moving when reloading arch model
Mon, Jan 5, 2015 at 9:01:02 AM
Walls keep moving
Fri, Apr 11, 2008 at 10:04:17 AM
Walls keep moving
Wed, Aug 25, 2010 at 5:16:11 PM
Page generation time: 0.2993
