Forums >> Revit Building >> Technical Support >> Phases and Worksets - Revit 2012
Thu, Aug 1, 2013 at 12:12:42 PM | Phases and Worksets - Revit 2012
mregan
I am starting a remodeling Revit project, with a existing, demo and new phases.  A discussion in our office has been - do you need to create separate worksets for the different phases.  CryingExisting workset, new workset, etc)
The argument is that worksets can be set to off in some views to allow for faster speed when opening the view.
Other argument is that phase filters already does that, so why would you have a 2nd way of filtering some items from a view.
Please advise!
Thanks!
Thu, Aug 1, 2013 at 12:27:05 PM | Phases and Worksets - Revit 2012
Phases and worksets are two different tools with different purposes.  If you have existing demolition and new in your projects, then by all means use phases.  Worksets can control visibility but that is not their primary use.  They are primarily a tool for multi-user but are useful even in single user projects.  Worksets can, and often do, cross phases in our projects.  I would not add phase based worksets.
Edited on: Thu, Aug 1, 2013 at 12:27:41 PM
Fri, Aug 2, 2013 at 8:15:14 AM | Phases and Worksets - Revit 2012
coreed
coreed Avatar
4 Stars: 16 Votes
Just so you cover all bases, you also might want to re-think the Demo phase.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Model Phases/changes
Mon, Aug 6, 2012 at 4:35:46 PM
Workset Management
Mon, Apr 1, 2013 at 5:18:37 PM
Showing multiple phases in one viewport
Tue, Jun 16, 2009 at 8:02:56 PM
Cant Delete one of My worksets...please help
Thu, Feb 14, 2019 at 1:48:12 PM
13
cannot enable worksets
Tue, Jan 23, 2018 at 11:00:18 AM
13
Page generation time: 2.4693
