Forums >> Revit Building >> Technical Support >> Cost parameter in Schedule doesn't work.
Wed, Jul 31, 2013 at 12:10:31 PM | Cost parameter in Schedule doesn't work.
jordyboardy
Hello all,
I've been lurking around this forum for a long time but always found my answers without asking questions so I have never needed to post a question. However today it's the first time I have not found my answer, therefore I am posting here to see if someone can help me out.
Using Revit 2012 Architecture (64-bit) and Revit 2013  (full version, 64-bit) both gave the same problem.
The problem is as follows.I have gotten a Revit file from my university and I need to make a schedule for two type of windows that consists of Family, Type, Count, Cost, and Total cost. This is not really a big deal, just add the parameters to a schedule, sort by family and type, uncheck "itemize every instance". Then create a calculated value called "total costs" with formula "cost" and type set to currency. Then in formatting go to the just created "total costs", check calculate totals and click ok.
Now there should be a schedule with the family, type, count, costs and total costs. But costs stays black and therefore total costs is 0,00.
To my knowledge windows have a certain cost associated with them that comes from a database that has values for all structures in revit. So my guess is that database isn't there or for some reason it doesn't work.
The file is 100% reliable, since my university supplied it to me and it works for others using the same version of Revit. Also this problem does not only occur with this file or just windows, the cost fields always stay blank. As mentioned the problem occurs on both Revit 2012 architecture (64-bit) and Revit 2013 (full version 64-bit).
If anyone could help me out, it would be greatly appreciated!
Thanks in advance!
Wed, Jul 31, 2013 at 12:18:34 PM | Cost parameter in Schedule doesn't work.
"....To my knowledge windows have a certain cost associated with them that comes from a database that has values for all structures in revit......"   Huh?
Where did you come up with that knowledge?   There is no such database that I am aware of.  Think about this - International use -!
Wed, Jul 31, 2013 at 12:37:20 PM | Cost parameter in Schedule doesn't work.
jordyboardy
I see, well that's pretty much the explanation I got from the helpdesk of my university, they couldn't help me out though.
Do you happen to have a solution?
Edited on: Wed, Jul 31, 2013 at 12:44:29 PM
Wed, Jul 31, 2013 at 12:51:24 PM | Cost parameter in Schedule doesn't work.
You will need either a shared parameter that you add to your families that you provide the information in, or you can add a project parameter to all mdel elements (unit cost) that you also fill in.
Estimating cost in our business is not easy.  It is regional and it is always changing.
If this is a real project, then you need real information.  If it is a school project, I would think you can use a number that you might find locally and that would be sufficient.  Talk to your prof.
Wed, Jul 31, 2013 at 1:12:55 PM | Cost parameter in Schedule doesn't work.
rkitect
rkitect Avatar
4 Stars: 29 Votes
You can actually achieve this just by simply putting your own value into the Cost parameter in the schedules you create and without even using a formula. All you need to do is create a schedule with Count and Cost parmaeters. I would also maybe put the Family and Type parameter in as well so you know which window it is. Sort by whichever parameter you want, probably Family and Type so that it groups all windows of the same type together. Then be sure you set Count and Cost to Calculate Totals in the Formatting section of the schedule properties. Turn on Footers for each sort group and grand totals and you can end up with this right out of the box:
See the video for a step by step. HTH
http://gibsonhh.info:8081/revit/video/130731-CostSchedule.swf
Edited on: Wed, Jul 31, 2013 at 1:22:14 PM
Thu, Aug 1, 2013 at 6:03:06 AM | Cost parameter in Schedule doesn't work.
jordyboardy
Thanks guys you solved my problem, appearantly there is no database with cost values installed in Revit unless you get a plug-in from somewhere. Inserting it manually did the trick!
Thanks again WWHub and rkitect! (cool name by the way)
Material Cost Analysis in Schedules
Wed, Jan 13, 2010 at 6:55:37 PM
Cost Modelling Schedule
Fri, Jan 30, 2009 at 10:05:09 AM
Area Schedule Estimated Cost
Fri, Aug 21, 2009 at 10:09:35 AM
calculated value - cost
Wed, Aug 13, 2014 at 11:18:35 AM
Material cost per sq ft formula
Mon, Sep 21, 2009 at 9:06:24 AM
Page generation time: 1.0790
