Forums >> Revit Building >> Technical Support >> Wall Hoisted Family Element Problem!! Help!!
Wed, Jul 31, 2013 at 4:00:05 AM | Wall Hoisted Family Element Problem!! Help!!
OwnageHawk
We've modeled a Hospital Bedhead Unit based on manufacturer drawings to place in our Revit Model.
Everything works fine except for the fact the unit is shrinks or increases with width based on the thickness of the wall.
We used a family template to start our model and the default wall thickness for the refernece planes is 150 mm; however none of our other wall hoisted elements have this problem.
If we try to attach it to a wall greater than 150 mm, the unit gets trimmed; if we attach it to a wall less than 150 mm thick it stretches to a new thickness...
I don't know what's going on.
Wed, Jul 31, 2013 at 7:22:45 AM | Wall Hoisted Family Element Problem!! Help!!
Without even opening the family, I know the problem.  Revit has a tendency to associate model elements with different planes in the wall hosted family.  You even may choose the wrong reference to dimension your elements off of when you create them in the family..
I always build wall hosted objects around a reference plane that is initially placed well away from the face of the wall.  Then when finished, we move this plane to the face of the wall using a dimension.
family element render materials [ 1 2 ]
Sat, Feb 14, 2009 at 10:47:01 AM
17
switching element type to curtain element error
Wed, Nov 16, 2011 at 1:37:03 PM
How do you Align a curved element to a flat surface
Thu, Oct 18, 2012 at 7:02:44 AM
Wall Sweep profile family problem
Tue, Oct 2, 2012 at 6:41:22 PM
2D Element into 3D Family
Tue, Jan 3, 2012 at 9:07:03 AM
Page generation time: 5.9693
