24 Users Online (22 Members):
Forums >> Community >> Newbies >> exporting revit to sketch up
10 Posts No Rating |
hello there,
I took the revit model to sketchup and put the materials then I set it for V-ray rendering but the problem is the rendered image is coming out very blurred like it not rendered at all my question is it is not possible to render revit model in sketch-up?
it is possible to do since exporting to CAD, colladea, etc just turns everything into solid blobs of geometry. You'd probably be better off visiting SketchUP forums to find out why your V-Ray plug-in isn't giving you desired results. I don't think this is a revit issue. My question to you is... if you have modelled already in Revit, why not just render within Revit?
1 Posts No Rating |
There could be a number of things causing this issue, have you enabled some form of motion blur? What type of lighting calculation are you using? Irradiance mapping, light cache or qmc? When in doubt put both your primary and secondary bounces to qmc and check your render. Have you tried using mental ray in revit?
Sketch up |
Thu, Mar 15, 2007 at 6:46:50 PM
Sketch up to revit |
Tue, Mar 26, 2013 at 7:31:17 AM
Question about sketch Mode |
Thu, Jan 17, 2013 at 6:34:56 PM
Revit into Sketch-up? |
Wed, Feb 17, 2010 at 1:08:26 PM
curtain wall sketch snapping problem |
Wed, Aug 12, 2009 at 8:54:07 AM
