Forums >> Community >> Newbies >> levels
Fri, Jul 26, 2013 at 5:59:21 PM | levels
RU52
I have read existing threads on this but am still stuck. Having trouble with levels in a linked model environment. I'm copy/monitoring the levels coming from the base buidling model. However I made some newbie mistakes in setting up our model. So I need to elminate some levels but can't find them anywhere to remove them. When I search by id, I can get to properties but "no good view found" when I select show. I guess my question is, if level still appears in properties, does it exist in some view somewhere or even if removed from an elevation, does it remain in the model? Thanks
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
Levels missing Revit 2012 [ 1 2 ]
Mon, Sep 28, 2015 at 3:29:41 PM
19
Levels, Disappeared. [ 1 2 ]
Sun, Sep 24, 2017 at 7:44:33 AM
16
Floor levels slightly offset
Mon, Nov 5, 2012 at 10:23:46 AM
walls look different on different levels
Thu, Mar 11, 2010 at 2:38:19 PM
Page generation time: 2.7551
