Forums >> Revit Building >> Technical Support >> im trying to export dwg. gives can't create or file " jpg " already open!!!!
Fri, Jul 26, 2013 at 4:19:55 PM | im trying to export dwg. gives can't create or file " jpg " already open!!!!
osama81
see the attach
Sun, Jul 28, 2013 at 9:55:30 PM | im trying to export dwg. gives can't create or file " jpg " already open!!!!
ronmalit
5 Stars: 3 Votes
with no detailed description of your scenario...
is there a jpg in your floor plan?
you inserted a jpg from desktop into your floor plan and now your trying to export that floor plan to your desktop?
if your overwriting existing files:
-have you tried to rename the jpg your trying to overwrite using windows explorer
-manually delete the existing files your trying to overwrite
if new file:
try to rename the original jpg you attached
** dont be mad, i dont have much... i am homeless
export to viz
Mon, Sep 26, 2005 at 3:04:27 PM
Exporting views for DWG
Thu, Oct 24, 2019 at 5:52:23 PM
Export to DWG - why is my file size SOOO big? (using Revit 2009)
Wed, Aug 6, 2008 at 3:52:25 PM
Revit Architecture 2009 - cannot open file using "file: open"..any help?
Wed, Jul 28, 2010 at 2:34:26 PM
"Can't create stringers geometry"
Mon, May 12, 2008 at 12:29:59 PM
Page generation time: 2.1854
