Forums >> Revit Building >> Technical Support >> exclude from masking region
Fri, Jul 26, 2013 at 10:01:13 AM | exclude from masking region
solidsnakeala
hello am using revit 2013 .... can i exclude some objects from the masking regions ??
Fri, Jul 26, 2013 at 10:09:44 AM | exclude from masking region
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Im assuming you are talking about families?  In that case no, you would have to create your masking region around those items.  Only 2D detail items have a drawing priority.
Fri, Jul 26, 2013 at 10:09:53 AM | exclude from masking region
Not model objects!  Redraw the masking region.
Fri, Jul 26, 2013 at 10:13:55 AM | WWHub
solidsnakeala
Quoting WWHub from 2013-07-26 10:09:53
 sorry what do u mean i dont get it !!
Fri, Jul 26, 2013 at 10:23:42 AM | exclude from masking region
Masking regions cover all model objects - there is no way to exclude any.
Masking regions placed over detail objects will mask them.  Detail objects can be placed over masking regions and will show.  You can pick on detail objects and pick send back / forward....  BUT no choices for model objects.
If you have modeled correctly, in most cases, you should not need masking regions.  Learn to use edit cut profile for model elements.
Sat, Jul 27, 2013 at 5:16:34 AM | exclude from masking region
solidsnakeala
thank you so much now i get the idea ..... but i think cut profile works only for sections not for elevations.. am i right ?
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
Masking region at section callout head.
Tue, Jul 30, 2013 at 1:43:26 PM
3D CAD import Part and masking region
Sun, Sep 14, 2014 at 2:36:26 PM
Masking Region doesn't seem to be masking
Thu, Mar 17, 2016 at 10:59:36 AM
Masking region in roof plan
Tue, Feb 24, 2009 at 3:14:03 PM
Page generation time: 0.1450
