21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Can't make type
Hello,
I keep getting the error "Can't make type "MB Round Column" when I try to place an instance of this family.
Have checked all the parameters for 0 values and tested all dimensions without error.
Many thanks in advance.
J
Revit Architecture 2013
ArchiCAD 16 Win
Windows 7 Enterprise 64-bit |
I'm sure it is a family issue. Flex the family according to your model.
sorry for asking but what do you mean by "flex the family"?
ArchiCAD 16 Win
In the family editor - your family shows a fixed floor to floor height. Is that the same height as your model. Also, the base portion has an adjustible height - set that according to your model. I see some "rings" above the base portion that are not flexible. I would bet something doesn't work here.
Got it!!
removed the contraint from the middle of the column and locke the top height. the base height keeps the adjustable parameter.
many thanks for your help.
J
ArchiCAD 16 Win
Can't make type error |
Wed, Oct 20, 2010 at 1:10:09 PM
Can't make type error message |
Tue, May 20, 2008 at 6:36:47 PM
Can't make type - no parameters in family |
Thu, Dec 8, 2016 at 6:39:58 PM
Can't Make Type Error |
Wed, Oct 7, 2015 at 10:03:48 PM
Making your first wall type assembly |
Wed, Apr 26, 2006 at 3:51:42 PM
