Forums >> Revit Building >> Technical Support >> dashed line for foundation footings?
Thu, Feb 9, 2006 at 1:48:55 PM | dashed line for foundation footings?
basia
hello - i am working on a foundation plan and need to have my footings appear with dashed lines. when i change the line type in visibility graphics, my foundation walls become dashed as well, which i do not want. is there a way to have the foundation walls appear with solid lines and the footings below to appear with dashed lines? thanks!
Thu, Feb 9, 2006 at 2:25:35 PM | RE: dashed line for foundation footings?
Thread Post Kudo! #2
Xane
Yes, pick on 'linework' icon, select line you want and pick on line which you want to change
Thu, Feb 9, 2006 at 3:33:01 PM | RE: dashed line for foundation footings?
kbsheppard
Well yes you could do that but why not let Revit do it for you. When I started I thought I'd have to use a reflected ceiling plan for the structural floor/roof framing members but the trick is to manipulate the cutting planes & viewing planes. In View Properties: 1) Discipline = Structural 2) View Range, Top = Associated Level Bottom = Unlimited View Depth = Unlimited Also make sure Floors are visible.
Thu, Feb 9, 2006 at 4:04:06 PM | RE: dashed line for foundation footings?
basia
thanks - my view range is set up exactly as you say kb, but the footing lines remained solid...xane's method worked out great for now.
Footings for Slab Foundation
Tue, Oct 30, 2007 at 7:05:08 AM
Changing Linetypes in Foundation Plan
Thu, Mar 18, 2010 at 7:18:01 AM
How to show Wall Ftgs with hidden linetype?
Tue, Sep 20, 2005 at 10:03:11 PM
Foundation Schedule - no footing thickness field - help!
Fri, Dec 2, 2011 at 10:24:44 AM
12
foundation footings
Tue, Jul 22, 2008 at 2:14:31 PM
Page generation time: 0.3397
