Forums >> Revit Building >> Technical Support >> Move Door in New Phase
Wed, Jul 24, 2013 at 1:12:59 PM | Move Door in New Phase
STBoyle
We want to simply flip a door swing in the new construction phase. How do we do this without creating a new door (extra door on door schedule)? This goes for a lot of items actually that we simply want to just save/move to new location. Thank you.
Wed, Jul 24, 2013 at 1:52:27 PM | Move Door in New Phase
You will have to have the new family.... NOTE:  You schedule can be - should be phased.
Wed, Jul 24, 2013 at 2:01:16 PM | Move Door in New Phase
STBoyle
Yes, figured there must have to be two doors in the same place, but one is demolished I suppose.
We filtered all demolished doors on the schedule out too. However, because we changed the existing door
to be demolished there is a wall fill now in its place. When we place the new door in the new construction phase,
it works ok, but it does not cut out the fill of the wall. We have to hide it in all views (RCP, etc). Is this correct?
Wed, Jul 24, 2013 at 3:09:37 PM | Move Door in New Phase
It should work correctly if hosted by the correct wall - the infilled one.
Existing door reused in proposoed phase
Tue, Oct 14, 2014 at 5:06:49 PM
Door Schedule Multiple Instances of Same File
Wed, Jan 30, 2008 at 10:48:23 AM
new door in exisiting wall
Wed, Jan 9, 2008 at 4:40:50 PM
how to tag new vs existing door/windoew of the same kind.
Fri, Nov 20, 2020 at 3:04:13 PM
Copying doors from one phase to another
Thu, Feb 7, 2008 at 2:29:40 PM
Page generation time: 1.4515
