11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Viewport Title References
1 Posts No Rating |
As I have been adding viewport titles to my different views on sheets, I realize that they aren't always referencing back to the correct sheet. I have gone back to those sheets and have hidden the element and continue to do that until I get it to read as the correct reference sheet. However, I have run into an issue where I have a floor plan referencing back to a sheet that only contains sections and therefore am unable to hide the callout. Why is that and is there a way to fix it? This is in Revit Arch 2013.
Thanks
Sorry but your question is not clear.
Are you using a viewport title that reports the original callout location. (The sheet cut from)?
Then if you add other callouts using the "reference other view" option, they will not report. Only the original callout reports.
Stretch/move text location in Viewport Title |
Wed, Sep 12, 2018 at 4:06:35 PM
Viewport title locked. How to unlock? |
Tue, Sep 30, 2008 at 3:20:48 PM
viewport title with line question |
Tue, Jul 8, 2008 at 11:38:17 PM
Viewport title rotation |
Wed, Oct 30, 2013 at 10:20:24 AM
Viewport Problem [ 1 2 ] |
Fri, Jul 6, 2012 at 11:27:21 AM
18
