Forums >> General Discussion >> Wishlist >> Edit Demolition Profile Tool
Thu, Feb 9, 2006 at 1:37:00 PM | Edit Demolition Profile Tool
arccodex1
3 Stars: 1 Votes
We have a number of projects where we have to delete a portion of a wall. We're trying to figure out how to demo unusual shapes out of a wall. It would be useful to have an edit demolition profile tool that attaches a profile shape to a specific phase. This way the shape of the wall can vary from phase to phase. Any workarounds?
Wed, Mar 1, 2006 at 3:28:01 PM | RE: Edit Demolition Profile Tool
quiller
quiller Avatar
2.5 Stars: 3 Votes
Workaround # 10003! You can demo a portion of a wall currently, but it must be square or rectangular shape. You first go in a section view and split the wall where the demo starts/stops. Then go into a plan view and split the wall again where the demo starts/stops. Then you can demo the portion in the middle.
Wed, Mar 1, 2006 at 4:43:33 PM | RE: Edit Demolition Profile Tool
latemore
latemore Avatar
3 Stars: 2 Votes
not a perfect work around, but you can insert a door/window opening in a wall, in a later phase and revit will show that 'bit' demolished in a demo view. then all you do is play with your 'opening'. problem is, the opening will appear in schedules,unless you put a filter on it.
edit cut profile tool
Thu, Aug 2, 2007 at 9:06:02 AM
big problem with edit cut profile????
Sun, Sep 11, 2005 at 9:38:48 AM
not able to edit profile in sweep
Thu, Jun 29, 2017 at 2:49:46 PM
Calculate Demolition
Fri, May 8, 2015 at 3:56:11 PM
edit cut profile
Mon, Aug 2, 2010 at 1:18:58 PM
Page generation time: 1.2564
