16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> endpoints not visible when using the align tool
I'm trying to create a door swing angle parameter but cant get the endpoints to highlight when I use the align command so I can lock the symbolic lines to the reference line.
You don't align to an endpoint.....just the line.
if you want to make angle parameter, follow this order.
1. draw ref line and make constraint one end point with two edges or lines of ref planes-(point to x&y location)
this makes center point of the angle concrete.
- use tab until point highlight with mouse over-
or just use intersection point of ref plane for one end point of ref line.  this makes constraint automatically)
2. make angle parameter
3. draw a line and make constraint align with ref line (line to line)
Edited on: Thu, Jul 25, 2013 at 1:16:29 AM
want more?
You can get more tips at Enjoy Revit |
Revit Architecture 2013 - Cannot dimension endpoints of walls/corners. HELP! |
Thu, Jul 18, 2013 at 8:24:17 PM
Is there a way to refence a particular 3d view on a floor plan? |
Thu, Sep 9, 2010 at 9:35:14 AM
Family & Align |
Mon, Aug 29, 2005 at 3:21:47 PM
Edit/Add trim to Door Family |
Thu, Jan 14, 2016 at 10:02:29 AM
Model Lines in Family |
Sat, Feb 25, 2012 at 5:32:08 AM
