Forums >> Revit Building >> Technical Support >> How to add brick banding below render?
Sun, Jul 21, 2013 at 6:09:04 AM | How to add brick banding below render?
jagodsell
HI, fairly new to Revit. I've created a wall type with a sto render externally which in reality would have min 150mm brick banding below - how do i create this within the wall parameters?
Thanks
Tue, Jul 23, 2013 at 7:36:30 AM | How to add brick banding below render?
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
You could make one wall ( the brick banding wall) only go up to 150mm from ground level. Then directly on top have another wall with your storender buildup starting at 150mm above ground level and going up to whatever you want.
Tue, Jul 23, 2013 at 8:40:10 AM | How to add brick banding below render?
You can do as Beaucoupnice suggests as seperate walls, or as a stacked wall (which is really separate walls  - in essance grouped together).  Or a more advanced solution would be to put the bick definition in a region in the lower part of the wall.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0330-Architec330/0331-Walls331/0336-Modifyin336/0347-Working_347
For beginners, the stacked wall is easier.
Unwanted Large-Scale Material Banding Effect in Renders
Thu, Jan 3, 2013 at 1:08:03 PM
Best way to render brick walls...
Thu, Jan 20, 2011 at 8:32:46 PM
Brick Colour
Mon, Jan 13, 2014 at 9:27:03 AM
Rendered brick different than brick jpg.
Tue, Jan 6, 2009 at 3:24:39 PM
Brick rendering at wrong scale and sideways
Thu, May 3, 2012 at 5:44:32 PM
Page generation time: 0.4923
