16 Users Online (14 Members):
Forums >> Workflow & Implementation >> API & Third Party Apps >> ISelectionFilter for CADLinkTypes
Hopefully I'm going about this the right way but with no sucess, I'm trying to make an ISelectionFilter to only allow picking of CAD files in a project. I've also tried using the CADLinkType class. My code so far is:
public class CADPickFilter : ISelectionFilter { public bool AllowElement (Element e) { if (e.Name.EndsWith(".dwg")) { return true; } return false; } public bool AllowReference (Reference r, XYZ p) { return false; } }
Thanks for any help.
I'll try again to make it more readable:
return true;
return false;
return false;
Try using RevitLookup to determine what properties you can use to filter the object.
It's part of the SDK and allows you to inspect elements that are currently selected. You'll be able to determine a class, category, or some other property that you'll be able to use for filtering.
Thanks so much! Should have thought of that before. I changed it to:
if (e.Category.Name.EndsWith(".dwg"))
and now it works as I wanted it to.
