Forums >> Community >> Newbies >> missing revit materials
Sat, Jul 20, 2013 at 8:40:52 AM | missing revit materials
raphuss
Good Afternoon all,
I am working on a project and now i need to attend materials before environment arrengements and rendering step. But there is a problem here tha somehow i couldnt solve. In my material library there are so insufficient materials on my materials list. I made a search to fix this problem and learned:
1- Revit materials cant be shared.
2- I may not have Autodesk Material Library and need to check if i have or not from control panel>programs.
Named for second, i have libraries (2014,base,low,medium) and i can see contents in program files(x86)>common files> autodesk shared>materials>2014. I didnt have any component and template libraries before this installation of revit and i learnt that i need to put *.autodesk.com into my trusted websites from internet options. I did this and reinstalled revit with this way by the way i made my component problem solved. But it seems didnt work for materials.
What can i do to access all standart materials that you use generally? For example in Autodesk materials there is no roof tab and in AEC materials there are only Wood shake and Asphalt Single. It is the factor that makes me sure that my list isnt enough to standart use.
Purged unused and now all of my materials are missing
Mon, Oct 28, 2013 at 11:43:17 AM
Missing materials
Wed, Jul 14, 2004 at 10:57:17 AM
Missing Materials
Wed, Jun 19, 2013 at 2:22:26 PM
materials keep going missing
Sun, Jan 10, 2010 at 4:05:40 PM
Revit materials missing at rendering [ 1 2 ]
Tue, Jun 14, 2011 at 11:24:21 PM
22
Page generation time: 2.3805
