Forums >> Revit Systems >> Technical Support >> Certain objects only showing up when highlighted.
Thu, Jul 18, 2013 at 12:52:22 PM | Certain objects only showing up when highlighted.
rryder1
I'm not sure if this is the correct forum. I am using Revit MEP 2012. In certain views objects arent appearing until either clicked on or highligted over. Does anyone know of any setting which could just make these visible. It's pretty hard to check drawings if what you see isn't what will print.
Mon, Aug 12, 2013 at 12:06:11 PM | Certain objects only showing up when highlighted.
wgfletch
cut a section and check the elevation of the objects then make sure that your view range is set so that you are able to see the objects
Mon, Aug 12, 2013 at 12:15:00 PM | Certain objects only showing up when highlighted.
Also be aware that most families are set up to display differently at different resolutions - coarse / medium / fine.
Objects showing up in elevations where I don't want them...
Tue, Jul 20, 2010 at 11:12:47 AM
Floor pattern showing through objects
Tue, Apr 1, 2014 at 10:49:06 AM
Window elements not showing in one elevation.
Mon, Jun 12, 2023 at 7:15:06 PM
Objects showing in wrong plan view
Sun, Oct 10, 2021 at 8:10:49 AM
Objects on floor above showing
Fri, Nov 13, 2020 at 4:19:52 AM
Page generation time: 1.2492
