Forums >> Workflow & Implementation >> Hardware >> What is the name of the file that lists the accepted video cards in Revit ?
Thu, Jul 18, 2013 at 9:34:25 AM | What is the name of the file that lists the accepted video cards in Revit ?
pjdarmstrong
   I once found the file that lists the accepted video cards, but have since forgotten where it is. I was able to add my GTX 460M to the list, but when Revit updates  that file is re-written.
Tue, Sep 3, 2013 at 7:03:53 AM | What is the name of the file that lists the accepted video cards in Revit ?
samjohnsonus
3 Stars: 2 Votes
ya same here..
Edited on: Thu, Sep 5, 2013 at 7:44:40 AM
Tue, Sep 3, 2013 at 7:40:19 AM | What is the name of the file that lists the accepted video cards in Revit ?
pjdarmstrong
samjohnsonus, don't you realize how disappointing it is to open a thread and find out you have nothing to contribute? If you want to chime in with useless anecdotes join a chat room. This is a "nuts and bolts" fix-it place!
Tue, Sep 3, 2013 at 8:15:12 AM | What is the name of the file that lists the accepted video cards in Revit ?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can find them here
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
Tue, Sep 3, 2013 at 10:14:09 AM | What is the name of the file that lists the accepted video cards in Revit ?
pjdarmstrong
teafoe5, I had no trouble finding Autodesk's list of accepted video cards. What I am asking about is the file inside the Revit program that lists the accepted cards. It can be hacked to include the card I'm using. Revit likes the GTX 460 already, but not the 460M (laptop card).
Tue, Sep 3, 2013 at 10:28:34 AM | What is the name of the file that lists the accepted video cards in Revit ?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"It can be hacked to include the card I'm using"
Is that really a good idea?
Eitherway I found this that may help
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16470651
Tue, Sep 3, 2013 at 10:29:48 AM | What is the name of the file that lists the accepted video cards in Revit ?
pjdarmstrong,
Where did you get the idea there was a file like this?
Tue, Sep 3, 2013 at 10:45:11 AM | What is the name of the file that lists the accepted video cards in Revit ?
pjdarmstrong
I finally found the file:  C:\Program Files\Autodesk\Revit 2014\AdskHardwareCertificationReport.xml
I successfully added my video card to this file a couple of years ago (in Dreamweaver), and Revit would go into the accellerated graphics mode with my laptop video card!
Found an Nvidia GEFORCE GTX400 series listing and copied it to another line, changed the number to 460M in the new line, and saved the file.
This time I had to change the permissions for that folder. Still have to see if Revit will "see" my card.  I wrote down the line number I added and might have to remove my changes if things go haywire, but as I said, it worked last time. The problem is that the file gets over-written when Revit is updated (they add new video cards that they have tested with Revit).
Tue, Sep 3, 2013 at 10:56:15 AM | What is the name of the file that lists the accepted video cards in Revit ?
Whether or not your card is listed here has nothing to do with how Revit works with the card.  Revit just uses the listing initially to see if your card is KNOWN to work.  If it is not, then Revit tells you but you can still use the card.
Sorry to bust your bubble.
Tue, Sep 3, 2013 at 11:22:12 AM | What is the name of the file that lists the accepted video cards in Revit ?
pjdarmstrong
WW Hub,  yeah, I got that page as well.  However, I can now use Ray-trace!, so I did something, even though Revit's telling me my card is untested. I should see if I can influence Autodesk to test and approve my card, but I doubt a corporation that big would hear me.
Thu, Sep 5, 2013 at 7:42:19 AM | pjdarmstrong
samjohnsonus
3 Stars: 2 Votes
Quoting pjdarmstrong from 2013-09-03 07:40:19
@pjdarmstrong: No issues, thanks for an unexpected comment. But I do have same problem. I have tried it in other search engines also, but couldnot get relevant solution.
Thu, Sep 5, 2013 at 8:09:14 AM | What is the name of the file that lists the accepted video cards in Revit ?
pjdarmstrong
Samjohnsonus,  my comment does look a little harsh in retrospect! And now that I have found the file I was looking for I'm a calmer man.
I graduated in Architectural Drafting in 2010 after a long career in residential and commercial building. Haven't done much with Revit for $$ as the building industry is still too slow here in Tucson, AZ.  How about you? Are you using Revit to earn?
New 2007 Autocad Lists Video Cards. Does Autodesk not do this for Revit?
Thu, Jun 15, 2006 at 8:43:12 AM
video cards
Fri, Mar 6, 2009 at 10:24:11 AM
Revit 2010 Video Cards
Tue, Sep 8, 2009 at 2:36:13 AM
Nvidia GeForce GTX 560 Not Recognized in 2012
Fri, Jul 13, 2012 at 4:50:04 PM
Dual video cards
Wed, Nov 24, 2010 at 3:27:00 PM
Page generation time: 1.4718
