11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Revit Architecture 2013 - Cannot dimension endpoints of walls/corners. HELP!
3 Posts No Rating |
Working in 2013 Revit Architecture and cannot snap onto corners or walls, door openings etc to do dimensioning. However it lets me snap onto them when I "measure" with the purple square showing up around the corner when I hover the mouse.
I've tried messing with cores/faces/centerlines option, and I swear I have endpoints/corners check marked to object snap. What could be the problem?
Please Help!
Thanks,
Matt
Have you tried liner dimension and see if it works in your case?
A workaround is to place an annotation line coincident with the line you want to measure. It will let you measure to that line.
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
3 Posts No Rating |
Yes, linear still wont snap and show the endpoint box I have quite a bit of dim lines to place and overlapping annotation lines would be pretty time consuming
I'm thinking it's some preference or setting somewhere that I may have messed up previously on the project. I would have swore it worked before early on.
_Matt
2 Posts No Rating |
Use "ALIGNED " always works
"LINEAR" has not worked riight since 2010 when AUTODESK brougt in the ribbon and the USER INTERFACE fix when people did not like the RIBBON.
Steve Z
Create in-fill walls under spiral stairs - Revit Architecture 2013 specific |
Thu, Jul 7, 2016 at 10:50:48 AM
endpoints not visible when using the align tool |
Thu, Jul 25, 2013 at 1:15:54 AM
Revit Architecture 2013 Question |
Mon, Apr 23, 2012 at 4:17:41 PM
Using tools in the Systems tab - Revit Architecture 2013 |
Wed, Sep 19, 2012 at 4:21:08 PM
"can't change dimension segment to this value" error 2013 pipes |
Thu, Oct 18, 2012 at 7:56:04 AM
