Forums >> Revit Structure >> Technical Support >> Analytical model edge cannot have a length of zero (0) error
Wed, Jul 17, 2013 at 9:51:07 PM | Analytical model edge cannot have a length of zero (0) error
laurence01
I recieving this massage "Analytical model edge cannot have a length of zero (0)"
i cannot delete or modify the wall, how to resolve this problem
Mon, Feb 10, 2014 at 3:29:11 PM | Analytical model edge cannot have a length of zero (0) error
Reviteer0612
I also received this error message when trying to create a floor slab.  I tried copying another slab and editing the shape, which went fine, but then when I went to move it into the correct position the error message persisted.  This error message also made the options bar a bit buggy as the options disappeared after that; saving during the edit mode prompted the options bar to come back up again (after dismissing the 'changes won't be saved' window).
The best solution I found for my floor slab was unchecking 'Enable Analytical Model' and 'Structural' from the instance properties of the slab.  I don't need them enabled so that works fine for me, but am curious as to how the error evolved in the first place.  Any thoughts?
Resetting/fixing the analytical model (Revit Structure 2014)
Wed, Jan 15, 2014 at 8:56:48 AM
Analytical Error Message
Thu, Jul 18, 2013 at 5:15:39 AM
Problem with adding analytical lines into Generic Model line template
Wed, Apr 10, 2013 at 3:31:06 PM
Revit 2017 No analytical model for curved wall
Fri, Feb 17, 2017 at 4:59:55 PM
Deactivate Analytical Truss and Slab
Wed, Feb 9, 2011 at 8:10:56 AM
Page generation time: 0.7752
