Forums >> Revit Building >> Technical Support >> Paint walls in Linked files
Wed, Jul 17, 2013 at 5:09:03 PM | Paint walls in Linked files
JD24
HI
I have a problem
We have an architectural model linked into an interior design file that does their own package with finishes and furniture etc...
Is there a way where we can use the material tag in the interior model and paint the walls in the interior model or add a material to the walls so we can tag it?
Or is there a better procedure for this in regards to having a linked file.
Wed, Jul 17, 2013 at 6:53:13 PM | Paint walls in Linked files
Sorry - paint is a model element and therefore you have to own the element being painted.
You can copy monitor walls and then turn off the architectural walls - then you own them.
Thu, Jul 18, 2013 at 8:40:54 AM | Paint walls in Linked files
JD24
i figured.
thanks ww
Remove Paint from Walls
Wed, Feb 9, 2011 at 1:33:46 PM
Paint Walls
Fri, Dec 10, 2010 at 12:02:23 PM
tagging linked files
Wed, Oct 19, 2005 at 6:29:00 PM
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
Dimensioning across multible linked files
Fri, Jan 15, 2010 at 10:33:16 AM
Page generation time: 0.8786
