Forums >> Revit Building >> Technical Support >> Revit Library Access Problem
Wed, Jul 17, 2013 at 8:28:51 AM | Revit Library Access Problem
raphuss
Hi,I cant reach any library files in revit. I meant at materials Autodesk Library, at components, at templates etc. I copied a 2013 programdata files of Revit, it contains some of these files but i figured now its not enough to use material part of Revit healthy.I cant find any materials which i want to attend.If there is a way to find Autodesk Materials as one folder or materials that produced by users, please tell me that cause i am so close to lose my mind.
I asked this to my friend and he told me that i need to go control panel>programs then install the libraries i want from there. But when i try this it wants revit 2013 architecture disk. I am not sure to burn a rac13 disk then continue for fix this problem. What can you say about this in addition?
Tue, Jul 23, 2013 at 7:51:13 AM | Revit Library Access Problem
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Big R Button ( top right) Options - file save path tab - set file save path to wherever your revit library folder was placed when you installed revit.
managing revit content library
Thu, May 3, 2018 at 8:37:26 AM
Revit content library
Mon, Dec 10, 2018 at 10:28:32 AM
Revit Problem Access Denied
Thu, May 6, 2004 at 2:04:14 PM
Accurender situation
Fri, Mar 30, 2007 at 1:34:58 PM
Custom Material Library Problem
Wed, Nov 13, 2013 at 4:18:49 PM
Page generation time: 2.1647
