Forums >> Revit Building >> Technical Support >> Modelling a chamferred recessed dock
Tue, Jul 16, 2013 at 6:56:11 PM | Modelling a chamferred recessed dock
billz1508work
Please find a quick diagram regarding an issue i am having. Usually this issue won't exist as i don't usually have to chamfer the dock, and where it is chamferred it has to be level for truck to get out. Has anyone achieved this accurately. I have made a building pad at -1320 below warehouse ffl. Usually i would just make a couple of floors at a slope though this isn't going to work in his case.I have drawn/marked in red how the truck has to get in and get out of the recessed dock, this is the only way as the council won't allow for truck to reverse in from the  street.The 3d image has the highlighted edges which i wish the falling slab to meet up witht he rest of the hardstand/concrete.cheers
Wed, Jul 17, 2013 at 8:33:49 AM | Modelling a chamferred recessed dock
This is not a lowered dock, just a depressed grade at the dock,  I would do this as a graded region in my topography.
Thu, Jul 18, 2013 at 3:48:58 AM | Modelling a chamferred recessed dock
jimmykingy1
a few options come to mind,
1.  split as floors at different level and join with ramp, this way you can control the buildup
2. create a floor based family and create a void to cut the host element the shape you want.
3.  use topography tool (possibly)
hope that helps as a starter...
Thu, Jul 18, 2013 at 5:33:54 PM | Modelling a chamferred recessed dock
billz1508work
Thanks for all suggestions. Had to bite the bullet, and just use the toposurface. In section and detail view i just ended up using detail line to get the ramp down a thickness/slab look. See attached.
Tue, Jul 23, 2013 at 11:27:11 PM | Modelling a chamferred recessed dock
billz1508work
Best Solution:Using a floor, and split it while adding multiple points and adjusting level. This is very accurate and the only way i would suggest if someone asked the question again. Thanks for the help.
DOCK DOORS THAN WILL CUT THE PIT FOR THE LEVELER
Mon, Jun 25, 2007 at 11:55:45 AM
How to make a recessed panel in a masonry wall
Fri, Oct 26, 2007 at 7:19:46 AM
RECESSED PANELS IN EXTERIOR WALLS
Mon, Oct 31, 2005 at 4:22:37 PM
Recessed cans in family
Sat, Jan 14, 2012 at 4:48:35 PM
Palettes Not working
Mon, May 4, 2015 at 6:37:12 PM
Page generation time: 0.9441
