14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Stack walls not cleaning well
I have some simple, stacked masonry walls that when alternated form masonry pilasters. They clean nicely in plan but I'm finding that in elevation unnecessary lines are drawn where masonry is in the same plane so there shouldn't be any lines. In the snip below I circle some lines that should be there. I find that sometimes when I go to plan and move a blue-dot handle, it gives Revit another chance to correct itself, which sometimes works, but not enough for me to clean up all my elevations.
Suggestions will be much appreciated.
Join the walls and see if that works. If not, you may have to breakup the stack.
Thanks. I checked and the walls are joined. I tried Disallowing Join and re-joining but it didn't help.
How would I "break up the stack?"
Right click on the stacked wall and you will see the command.
More stack wall problems! |
Sun, Apr 8, 2007 at 3:40:16 PM
Walls not cleaning up |
Mon, Nov 16, 2009 at 11:21:52 AM
Stack Wall Problem |
Thu, Jun 4, 2009 at 3:17:56 PM
Stack Wall Problems! |
Wed, Feb 14, 2007 at 2:52:29 PM
Quoin stack |
Sun, May 10, 2009 at 4:44:28 PM
