Forums >> Revit Building >> Technical Support >> Circular hut-type roofs
Thu, Feb 9, 2006 at 1:56:04 AM | Circular hut-type roofs
amberjo
Circular hut-like roofs--can anyone tell me how to make them? Thanks, Amber
Thu, Feb 9, 2006 at 2:37:30 AM | RE: Circular hut-type roofs
jobcaptain
jobcaptain Avatar
1 Stars: 2 Votes
use the roof command > by footprint select the lines feature > use a circle once the circle is created (stay in sketch mode) pick the circle you just created. pick properties and set the number of full segments to "0" (zero) finish the sketch > you now have a round hut roof. Cheers!
LinkedIn Profile:
  • http://www.linkedin.com/in/danielhughes1/
I author Bradley BIM Blog: http://bradleybim.com
Thu, Feb 9, 2006 at 2:42:06 AM | RE: Circular hut-type roofs
SuryaRamesh
1 Stars: 1 Votes
First,create the circular wall with walls-sketch-circle. now you build another straight wall joining two opposite quadrant points of the circular wall.draw a section nside so that you'll get this straight wall in head on elevation.go to the section view.now create family-roofs-solid-revolve.when you are in sketch mode , pick the straight wall as your plane.give the axis at the center,profile will be a sloping double line with the top end toucing the apex of the roof and bottom end toching the end of the slab. finish the sketch..that's it.
Circular Sloped Roof in Revit
Tue, Jul 19, 2016 at 9:43:06 AM
Parametric Circular Column...Offset issues
Tue, Jul 17, 2012 at 12:42:38 PM
Circular Arch
Tue, Jul 21, 2015 at 9:06:15 AM
What type of window are these????? HELP~~
Sun, Feb 19, 2012 at 2:47:53 AM
Newbie: Wot no ref planes in Circular Handrail.rfa
Mon, Jun 1, 2009 at 4:26:00 PM
Page generation time: 0.8500
