Forums >> Revit Building >> Technical Support >> Problems rendering with Artificial Lights in Revit 2014
Fri, Jul 12, 2013 at 5:13:31 AM | Problems rendering with Artificial Lights in Revit 2014
sharlandm
Hi There,
I am having the most bizarre problem.  For some reason, the artificial lights I have inserted into my revit 2014 model do not register when I go to render.  If i am in plan view, I can select the light fitting, and it comes up with the option to add it to a group etc (so it registers that it is a light fitting). However, when I go to a camera view and open the rendering dialog box, I set the lighting setting to interior sun and artificial and try to click on the 'Artificial Lights' tab to turn them on, nothing happens. Nada. Nix.  The lighting dialog box should pop up so I can select the lights to be switched on but nothing happens.
I used the exact same light fitting in a different project and it worked just fine.
Does anyone have any suggestions on how I might fix this?
Fri, Jul 12, 2013 at 7:14:56 AM | Problems rendering with Artificial Lights in Revit 2014
This is probably either a light fixture problem - a lens around the light source is a solid instead of transparent material or the light is above the ceiling and does not cut a hole in the ceiling.  << I bet it is a material issue.
Fri, Jul 12, 2013 at 7:20:10 AM | Problems rendering with Artificial Lights in Revit 2014
sharlandm
I have checked the materials and the lens is transparent, and the light fitting is cutting correctly (and as I said I have used that exact family before and it worked perfectly). I even tried with a completely different fitting and had the same result.
Fri, Jul 12, 2013 at 8:04:10 AM | Problems rendering with Artificial Lights in Revit 2014
Using the same fitting before doesn't matter if it was a different version of Revit or even just a different project so heed the warning....
I re-read your question ....The Artifical Lights is not greyed out or is it black with a blue border?
Fri, Jul 12, 2013 at 8:28:49 AM | Problems rendering with Artificial Lights in Revit 2014
sharlandm
The Artificial Lights button in the rendering dialog box is the normal grey colour, not ghosted or black. When I click it, it goes blue and then pulses blue, but no lighting dialog box comes up.
Fri, Jul 12, 2013 at 8:42:18 AM | Problems rendering with Artificial Lights in Revit 2014
Lets determine if it is your program or your project.  Open the sample project that comes with 2014 and goto the 3D View and render dialog... what happens these?  Does the light settings work?  If so, then something is wrong with your file or lights.  If not, then your Revit may be corrupted.
Fri, Jul 12, 2013 at 8:59:52 AM | Problems rendering with Artificial Lights in Revit 2014
sharlandm
In the sample project, the Artificial Lights button works as it should, so Revit is not corrupted.  What could be the problem with the project that this is happening?
Fri, Jul 12, 2013 at 9:06:55 AM | Problems rendering with Artificial Lights in Revit 2014
Create a new project and place one of these lights - what happens....?
BTW - Are you using design options?
Mon, Jul 15, 2013 at 2:21:49 AM | Problems rendering with Artificial Lights in Revit 2014
sharlandm
In the new project, all lights work normally.  I am not using design options.
Wed, Jul 17, 2013 at 5:10:41 AM | Problems rendering with Artificial Lights in Revit 2014
sharlandm
Well I managed to sort the issue in a very round about way. I just started a new project and linked the original project to that. Then the lights registered and rendered normally (thank goodness!).  I'm still not quite sure what might have caused the original problem, but at least there was a work-around.
Wed, Nov 6, 2013 at 5:20:19 PM | Problems rendering with Artificial Lights in Revit 2014
tlh09c
I'm having this same problem - (I've tried everything!) how did you link a new file to your old one?
Tue, Nov 12, 2013 at 8:13:03 AM | Problems rendering with Artificial Lights in Revit 2014
moffatt
moffatt Avatar
5 Stars: 2 Votes
It sounds like you need to make a lighting link to turn them on I had the same issue a while back and learned to link them together. Click the render button in the ribbon then in that window click artificial lights after you have one of the artificial light selections picked sun and artificial etc.. By default all of your lights that it recognizes show up in an ungrouped folder, click new name it lighting link, then one at a time move all of your lights to the new lighting link folder using move to group. once they are all in the grouped folder lighting link click ok and try it out I hope this helps.
Wed, Nov 13, 2013 at 9:05:12 AM | Problems rendering with Artificial Lights in Revit 2014
#13
sharlandm
@TLH09C, I simply created a new project (eg project-Y), opened the "Insert" tab, selected "Link Revit" and linked in the project (eg project-X) with the faulty lights. You can't edit project-X in project-Y, but any chnages you make to project-X will be updated in project-Y.
Revit always renders all of the lights
Fri, Aug 8, 2014 at 9:24:36 AM
Revit 2009 - interior rendering with exterior sun and artificial lights
Fri, Oct 10, 2008 at 10:25:18 AM
lighting scheme and artificial lights
Mon, May 19, 2008 at 9:21:47 PM
rendering: can't get itnerior lights turned off
Mon, Feb 27, 2012 at 6:14:44 AM
artificial lights not rendering
Tue, May 7, 2013 at 6:52:56 AM
Page generation time: 2.9179
