Forums >> Revit Building >> Technical Support >> What is the best way to create corner boards?
Wed, Feb 8, 2006 at 11:19:43 PM | What is the best way to create corner boards?
Tmifsud
In a residential project with horizontal wood or vinyl siding, what is the best way to indicate corner boards? I've tried creating a custom profile and then applying a vertical sweep but I can't get the corner board to position properly. Thanks!!
Fri, Feb 10, 2006 at 10:11:23 AM | RE: What is the best way to create corner boards?
kesflower
3.5 Stars: 11 Votes
I just uploaded a very simple corner board that someone in our office made. It started as an in place family, which is what I would suggest for cornerboards with lots of detail. Ruth
Fri, Apr 13, 2007 at 3:00:23 PM | What is the best way to create corner boards?
Tmifsud
Thanks.  Lately I've found that I prefer to split the face and use paint tool to apply a different material to represent the corner board.
Fri, Apr 13, 2007 at 3:34:11 PM | What is the best way to create corner boards?
framerman
4 Stars: 13 Votes
I think that would be a temporary thing to do, the split faces. Once you really get going, use the family because it will give you a more accurate model representation thus leading to a better documented model. Meaning better takeoffs
REAL Corner boards
Thu, Oct 27, 2005 at 3:51:59 PM
Corner boards
Fri, Apr 21, 2006 at 11:38:12 PM
corner boards
Sun, Dec 18, 2005 at 4:50:54 PM
Skirting boards
Tue, Dec 15, 2015 at 3:36:54 AM
corner trim
Fri, Apr 2, 2004 at 2:17:39 PM
Page generation time: 1.7537
