Forums >> Revit Building >> Technical Support >> Custom Mullion - Panels position
Thu, Jul 11, 2013 at 10:57:56 AM | Custom Mullion - Panels position
joac21
Im trying to create a custom mullion, follow the instructions in other topics but the panels appear far away from the mullion...
i also want the mullion to be at the end of the floor. (see attached)
im using Revit 2013
Anyone could help ?
Image 1 i what im doing. Image 2 is what is happening, Image 3 is what i want.
thanks!
Thu, Jul 11, 2013 at 11:58:03 AM | Custom Mullion - Panels position
Thread Post Kudo! #2
Curtain walls have a location line.  Then the curtain wall panels and the curtain wall mullions have an offset parameter that you can change to set where they are in relation to that location line.  Adjust the offset of your mullions or your glass as needed.
Thu, Jul 11, 2013 at 12:01:22 PM | Custom Mullion - Panels position
joac21
where do i change those parameters ?
Thu, Jul 11, 2013 at 12:11:58 PM | Custom Mullion - Panels position
Why don't you click on one (mullion or panel) and look at the properties?  Easier to just look before you ask the question.
Thu, Jul 11, 2013 at 12:19:56 PM | Custom Mullion - Panels position
joac21
If you want to help. thank you very much, if you dont, dont.
Thu, Jul 11, 2013 at 12:23:36 PM | Custom Mullion - Panels position
I'm a firm believer in teaching a man to fish rather than feeding him.  It does take a little effort to fish .... but it is just a little effort.  Children still expect to be spoon fed.
Thu, Jul 11, 2013 at 12:26:29 PM | Custom Mullion - Panels position
joac21
haha fair enough
Custom Mullion Profile
Thu, Apr 23, 2009 at 3:47:59 PM
Curtain wall custom panels "FLIP"
Mon, Feb 18, 2008 at 5:30:43 PM
Curtain wall panels not trimming correctly against mullions
Thu, Dec 10, 2009 at 5:49:55 PM
Mullion Will not Join IF Mullion is Less Wide than Tall
Tue, May 19, 2015 at 11:03:13 PM
Butt Glazing Non-System Curtain Panels
Wed, Nov 12, 2014 at 1:28:25 PM
Page generation time: 2.8186
