Forums >> Revit Building >> Technical Support >> Staircase Sketching - Riser count not reducing in number
Thu, Jul 11, 2013 at 5:40:37 AM | Staircase Sketching - Riser count not reducing in number
porky996t
Hi Guys,
First post here...I have moved over to Revit 2013 after using ACAD for 14 years... I'm getting used to it now; a bit of a learning curve, however, the productivity increase is welcomed.
Just one small query when designing a staircase. I am using the sketch method, and when I draw the first riser, the text on screen recognises this and states "1 riser - 11 remaining", but any riser I do draw after this first one is then not recognised. The text remains at "1 riser... etc" no matter how many risers I subsequently sketch in.
I initially used the offset tool to draw in the rest of the risers and noticed the riser count didn't change, and now after an hour of trying various ways of sketching risers I am still no further forward.
Any guidance will be gratefully appreciated - thanks in advance of all suggestions.
custom riser height for staircase
Wed, Mar 24, 2010 at 12:08:35 AM
How to create Folded Plate Staircase
Wed, Dec 17, 2008 at 4:09:59 PM
New Stair Tag Family!
Tue, Nov 11, 2014 at 1:48:59 AM
Staircase - Issues with Plan Graphics/Representation.
Sat, Sep 18, 2010 at 11:54:22 PM
Schedules - Calculated Value does not have "Count" in the list of fields
Thu, Oct 17, 2013 at 8:55:44 PM
Page generation time: 1.2351
