Forums >> Revit Structure >> Technical Support >> Reinforcement in round columns
Thu, Jul 11, 2013 at 4:07:43 AM | Reinforcement in round columns
edgars112
Hello! I have problem which I cant solve. How can I arange rebar set in round column so that rebars would be in circle? If I create rebar set I can only arrange them in square. Also I wanted to know if I create rebar sets can I only make constraints with object faces and covers or there is a way how to create constraints between different rebar sets?
Thank you
Mon, Jul 15, 2013 at 1:52:38 AM | Reinforcement in round columns
edgars112
Problem solved using revit2013 extensions. Thanks
Mon, Jul 15, 2013 at 6:43:37 AM | Reinforcement in round columns
caddeva
Thanks for the tip.but i figure out simple issue in revit extension 2013. i create a round column and select the reinforcement in extension,rebars is comes automatically, but my problem is ,if i change the VISUAL STYEL- SHADED  and DETAIL LEVEL - MEDIUM i can view the  main rebars and strirups. but i changed like this DETAIL LEVEL - FINE and  VISUAL STYLE - SHADED  i can't view the stirrups, even i tried VG also. how can i clarify this.
Please see the attachment.
Mon, Jul 15, 2013 at 7:07:12 AM | Reinforcement in round columns
edgars112
I think you just need to change transparensy in graphic display options. mine is set to 54 with fine and shaded.
Mon, Jul 15, 2013 at 8:11:54 AM | Reinforcement in round columns
caddeva
Thanks for your reply. but i have tried too (Grapic Display Option). it's not working... please see attachement
joining two round columns together
Tue, Jul 16, 2013 at 6:28:05 AM
Attaching Beams to a Round Structural Columns
Mon, Jul 15, 2013 at 8:26:16 AM
Rebar/Reinforcement Scheduling Area Reinforcement
Wed, Mar 9, 2011 at 4:59:36 PM
Reinforcing Tags
Thu, Jan 2, 2014 at 1:15:45 PM
path reinforcement tag and symbols
Sat, Dec 7, 2013 at 12:16:36 PM
Page generation time: 0.0705
