23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Parts Tool Issue
Hi Everyone. I'm using Revit Architecture 2013.
I'm drawing an existing building and we are removing some of the existing finishes and replacing it. I tried to use the parts tool to separate the wall finish from the rest of the existing wall and changed its phasing to be demolished. When I looked at my demolition and new plans, the finish was still there.
Is there a way to fix this? Also, was the parts tool the right tool to use in this case or should I just draw the existing wall and the finish separately?
I would do this differently. I suggest using a thin wall over your base wall with the two joined. All doors / windows & openings will still work and you can demo to your hearts content.
Parts v cut profile |
Wed, Feb 8, 2017 at 11:01:08 AM
Painting seperate parts of walls? |
Wed, Feb 4, 2015 at 8:22:44 AM
3D view issue |
Sat, Dec 11, 2010 at 7:05:48 AM
Parts / Structural Deck Visibility |
Mon, Jun 15, 2015 at 5:00:30 AM
Parts |
Fri, Sep 16, 2011 at 2:25:10 PM
