Forums >> Revit Building >> Technical Support >> Model not visible in Ceiling Plan views
Wed, Jul 10, 2013 at 11:09:42 AM | Model not visible in Ceiling Plan views
JBRADLEY
I just had REVIT 2014 installed.  For some reason my model isn't visible in other Floor Plan views.  I am trying to create a ceiling plan view like I have done with Revit 1,000 times.  Why isn't the model visible in any view except for the view that I started modeling it in  to begin with?  The only entities visible are the Grid lines?  The only way I can see my model is to "Duplicate" the view.  I have adusted the View Range up/down. Nothing is turned off in the Visibility and graphics.  No links in my project.  No filters or worksets either.  Please help.
Wed, Jul 10, 2013 at 11:19:43 AM | Model not visible in Ceiling Plan views
JBRADLEY
Ok.  I think the problem is,  I started with a "Construction" Template instead of an "Architectural" Template.  The "Construction" template is the first choice when starting a new project in RVT 2014 instead of the "Architectural" Template that has been the Default option to choose from in previous releases.
Wed, Jul 10, 2013 at 12:16:06 PM | Model not visible in Ceiling Plan views
Thread Post Kudo! #3
I deleted the templates we don't use so they don't even show up in the list.  You can also set what template is defaulted to.
The difference the template will make is what your view settings are ... you can change those.
Wed, Jul 10, 2013 at 12:56:49 PM | Model not visible in Ceiling Plan views
JBRADLEY
Yes.  I just found out how to set the default template to architectural.  Thanks for your help.
Ceiling tags: how can i make them visible in floor plan views
Thu, Dec 6, 2012 at 3:59:35 PM
Linked Structural model not visible is certain rotated section views
Tue, Dec 22, 2015 at 2:27:12 PM
11
Lines in Ceiling Plans
Wed, Oct 24, 2007 at 4:44:57 PM
Sections lines not visible in certain plan views.
Wed, Dec 14, 2005 at 11:30:15 PM
Ceiling Model Lines Showing up on Floor Plan
Tue, Dec 13, 2011 at 6:04:04 AM
Page generation time: 0.9048
