Forums >> Revit Building >> Technical Support >> Adjust Wall Ends
Wed, Jul 10, 2013 at 8:11:48 AM | Adjust Wall Ends
cboersen
Revit 2013
In section you can unlock a wall material end and drag them up and down for brick ledges or whatever.  Is there a way to do this in plan as well?  I would like to unlock the wall ends so I can adjust each material separately at wall ends in plan.
Wed, Jul 10, 2013 at 8:16:50 AM | Adjust Wall Ends
No, You can't do this.
  1. You can set wall wraps in the wall definition.
  2. You can "paint" the ends of walls with a material
  3. and in plan views, uou can edit the cut profile (2D only solution).
Wed, Jul 10, 2013 at 8:30:19 AM | Adjust Wall Ends
cboersen
1. Does not quite do what I want.
2. Only in elevation I assume - explain if it can be used in plan.
3. Can you elaborate on "edit the cut profile" in plan view.  I cannot find any Revit HELP on that.  Thanks.
Wed, Jul 10, 2013 at 8:33:00 AM | Adjust Wall Ends
Edit Cut profile tool is under the view tab.  It is available in all 2D views and is described in your HELP here:
Changing the Cut Profile of Elements
Wed, Jul 10, 2013 at 8:59:50 AM | Adjust Wall Ends
cboersen
Very nice.  That did the trick.  Thank you very much.
Wed, Jul 10, 2013 at 9:08:25 AM | Adjust Wall Ends
Learn to use this tool in section views too so you don't have to add filled regions.
Wall end at an angle
Mon, Apr 14, 2014 at 4:26:52 PM
non orthogonal wall ends
Wed, Jul 18, 2007 at 12:51:57 PM
Course Detail Level Exposes Wall Ends
Fri, Nov 4, 2011 at 1:16:57 PM
Wall Ends No going to Gridlines
Fri, Apr 9, 2010 at 2:04:02 PM
REVIT 2013 - Angled Layered Wall Ends
Tue, Dec 3, 2013 at 8:18:33 AM
Page generation time: 1.5624
