Forums >> Revit Building >> Technical Support >> Controlling curve width & depth in a family. Revit 2014
Tue, Jul 9, 2013 at 7:21:29 AM | Controlling curve width & depth in a family. Revit 2014
DavidBS
Hope this si the correct forum.
I am trying to create a worktop with a curved front edge and flat rear edge & sides. There is a parameter set to the rear flat edge controlling the width and one fixin the curves depth (using reference planes). What I want is to fix the curves depth but allow it to stretch. I can do this using model lines, but as soon as I change it to a 3D object it fails. Any help would be appreciated.
Thanks
Dave
Tue, Jul 9, 2013 at 8:19:42 AM | Controlling curve width & depth in a family. Revit 2014
Download the "Families Guide" from the AutoDESK site and read the chapters on doors as well as Using Reference Lines in Families.  I believe you will find your answer there.
Tue, Jul 9, 2013 at 8:47:44 AM | Controlling curve width & depth in a family. Revit 2014
DavidBS
WWHub,
Thank you.
Dave
How to Make random depth dimension in a nested family.
Thu, Nov 19, 2009 at 8:56:26 PM
Way around circular formuala references?
Tue, Nov 19, 2013 at 6:15:48 AM
Creating a new fireplace & chimney
Tue, Nov 18, 2008 at 6:00:48 AM
Controlling visibility of nested families in familes with multiple types
Mon, Jan 6, 2014 at 10:37:45 PM
Controlling Yes/No Parameters with Formula
Thu, May 29, 2008 at 7:53:19 AM
Page generation time: 1.7353
