Forums >> Revit Building >> Technical Support >> Cut a window into a tube
Wed, Feb 8, 2006 at 3:53:26 PM | Cut a window into a tube
strad1
Hi, does anyone know how you might create a tube like structure with windows or port holes along its curved sides?
Wed, Feb 8, 2006 at 4:50:23 PM | RE: Cut a window into a tube
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Are the portholes going to have curved/warped glass to match the tube? If not and the tube is created using massing walls, you should be able to place circular windows in them but they will be placed to normal x/y axis.
Wed, Feb 8, 2006 at 6:23:10 PM | RE: Cut a window into a tube
strad1
Yes, I was hoping to create eliptical shaped windows along the side of a tube, similar to an aircraft but larger, curved would be nice, same cross sectional profile as the tube. Thanks
Wed, Feb 8, 2006 at 8:43:21 PM | RE: Cut a window into a tube
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I think the easiest way would be to model the windows in a family that is unhosted (already shaped to the tube etc. Then place your windows in space and create openings for them.
Thu, Feb 9, 2006 at 5:08:43 AM | RE: Cut a window into a tube
strad1
I can create a horizontal tube using the create mass tool, but cant find how to create an opening along its curved side?
Thu, Feb 9, 2006 at 5:36:23 AM | RE: Cut a window into a tube
strad1
Correction, I can create a square / rectangular opening but not an eliptical or round one!
Thu, Feb 9, 2006 at 5:54:52 AM | RE: Cut a window into a tube
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Create a void extrustion in the mass itself.
Thu, Feb 9, 2006 at 6:15:32 AM | RE: Cut a window into a tube
strad1
I can create a void extrusion but only in one plane, ie looking down on the cylinder "0", not sure how you can create a eliptical profile at 90 degrees to this plane ? forgive my ignorance, I am a relatively new user Smile
Mon, Feb 13, 2006 at 4:29:00 AM | RE: Cut a window into a tube
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You need to draw a reference line in plan first, then set that as the work plane for the extrusion... you will then be prompted to go to a section/elevation where this plane can be seen at an angle to the screen.
cutting a HSS tube
Wed, May 23, 2012 at 2:06:22 PM
window does not get cut in plan view.
Tue, Jul 12, 2011 at 10:37:20 AM
Easy family u tube vid Rev 2012
Sun, Nov 4, 2012 at 8:17:12 PM
Need help: modeling tube to tube intersection w/ in-place families
Wed, Nov 11, 2009 at 7:15:36 PM
Wiring a 3 tube light
Thu, Jun 23, 2011 at 3:01:48 PM
Page generation time: 0.4322
