Forums >> Revit Building >> Technical Support >> slab edge visibility issue
Sun, Jul 7, 2013 at 6:59:46 PM | slab edge visibility issue
spacey
Hi,
I am using Revit Architecture 2012
I would like to show my slab thickenings as a dashed line, (preferably all edges, but any woul be bettter than what I have now!) and the boundary edges of the floor slab as a solid line.
In the attached model, there are several slabs of different heights, and  the slab edge shows up as a solid line on the slab at -165, and on the other slabs not at all.
When I add a visibility overide to slab edges, say dashed, it changes the visible one (on slab at -165) to dashed, and shows the boundary of the other slabs as dashed but doesn't make the slab edges visible on them.
 I have tried using the "show hidden lines" tool on the view menu, but this makes no apparent difference.
What have I done wrong?
I have seen a lot of comments about changing the revit.ini file for slab edge visibility. Is this necessary in this version to achieve what I want?
I have to admit to being very wary of changing it, as the explanation here (http://revitclinic.typepad.com/my_weblog/2011/05/deploying-revit-2012-with-a-customized-revitini-file.html Winking confused me.
Thanks for any help.
Mon, Jul 8, 2013 at 1:24:05 AM | slab edge visibility issue
ronmalit
5 Stars: 3 Votes
hi,
theres no attached model.
but in worst case scenario, i will choose to use linework(LW) instead of messing with the unknown (.ini)
** dont be mad, i dont have much... i am homeless
Mon, Jul 8, 2013 at 1:48:24 AM | slab edge visibility issue
spacey
Hi,
Sorry: I can't seem to upload the file.
Mon, Jul 8, 2013 at 7:32:41 AM | slab edge visibility issue
You could not upload because file sizes are limited so you probably exceeded that limit.
Please read this subject in your HELP:
Showing Hidden Element Lines
Mon, Jul 8, 2013 at 4:23:08 PM | slab edge visibility issue
spacey
Thanks, I thought I had shrink it enough, but not quite. Here it is finally:
Tue, Jul 9, 2013 at 8:35:12 AM | slab edge visibility issue
Did you read the HELP chapter I pointed you to?
Is there a way to half tone the slab but still have the slab edge shown full
Thu, Nov 12, 2009 at 6:58:58 AM
Slab edge profile not available
Tue, Nov 10, 2009 at 1:56:29 PM
"Could not create Slab Edge"
Tue, Feb 17, 2009 at 1:40:42 PM
RC upstand on the edge of an RC slab
Thu, Jul 14, 2011 at 11:04:56 AM
Slab edge and abc confrontation
Wed, Dec 21, 2011 at 2:31:44 PM
Page generation time: 1.6132
