13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Constraining a Model In Place Wall
10 Posts No Rating |
I'm wondering if it's possible to constrain a model-in-place wall to a level? Bit of context, documenting a 3-storey apartment and the construction system is pre-cast modular boxes basically, and modelled a box as a wall (to allow doors/windows to work). These boxes stack on top of each other, however still working out the exact levels. I've set the levels up but wondering if it's possible so when I move a level (or a reference plane even) up or down the wall moves with it? Currently it just stays where it is, but I can manually move it, just trying to see if it can be automated.
Why didn't you use Revit walls? << Much better solution. Maybe it's not too late to change.... remember, you can group them to form your box.
In-place models are contolled by the sketeches and workplanes that define them. In-place models are meant for "one-of-a-kind" use, not really to be copied around.
Help Can't create reveals on model in place wall |
Thu, Jan 5, 2017 at 1:22:53 PM
Change the MODEL IN PLACE - type Roof into curtain wall solar panel. |
Wed, Aug 14, 2013 at 7:03:04 AM
Door wont cut into in place model wall. |
Mon, May 3, 2021 at 10:21:46 PM
Model in in place walls and Doors |
Thu, Mar 23, 2017 at 3:19:24 PM
Walls joining: in-place model + regular wall [ 1 2 ] |
Wed, Jul 29, 2015 at 4:10:39 PM
15
