Forums >> Revit Building >> Technical Support >> Revit render more artificail light then i wanted to
Thu, Jul 4, 2013 at 8:15:39 AM | Revit render more artificail light then i wanted to
danezeq
Hello everyone
I activated artifical light when redering, and the redering progress window says "Artificail lights: 82" though i turned all of them off in the "artificail lights..." button
When i turn on the lights i placed which i need to render, it shows "Artificail lights: 92"
so i need to process only 10 of them - and the render goes terribaly slow.
btw - when i'm hiding familites that has lights in it - the number of artificial lights goes down. (before that it was  140)
how can i turn off ALL the artificail lights i don't need to process?
Thu, Jul 4, 2013 at 8:44:28 AM | Revit render more artificail light then i wanted to
4 Stars: 205 Votes
You must check this first: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2034-Renderin2034/2038-Lights2038/2076-Light_Gr2076
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2034-Renderin2034/2038-Lights2038/2076-Light_Gr2076/2083-Turning_2083
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2034-Renderin2034/2038-Lights2038/2065-Using_Li2065/2072-Controll2072/2075-Dimming_2075
Edited on: Thu, Jul 4, 2013 at 8:45:10 AM
Wall light can't render problem
Wed, Mar 31, 2010 at 1:06:13 AM
custom light fixture, Revit 2009
Fri, Mar 11, 2011 at 9:28:44 AM
Light Source
Thu, Feb 19, 2009 at 8:01:01 AM
White spots on render. Light issue.
Thu, Jul 30, 2015 at 1:01:48 PM
Light fixture doesn't produce light
Sat, Jun 7, 2008 at 12:39:38 PM
Page generation time: 3.6164
