13 Users Online (12 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Array Groups within Detail Groups
Wed, Jul 3, 2013 at 12:07:19 PM | Array Groups within Detail Groups
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
Hi All,
This one seems like a no-brainer, and maybe I'm missing something, but is it not possible to array linework or detail elements within a detail group? Doesn't seem like rocket science but for the life of me I can't get it to work.
Revit Architecture 2013
Edited on: Wed, Jul 3, 2013 at 12:07:51 PM
Wed, Jul 3, 2013 at 9:20:25 PM | Array Groups within Detail Groups
dingohot
dingohot Avatar
3.5 Stars: 5 Votes
why don't you use Repeating Detail Component?
want more?
You can get more tips at Enjoy Revit
Mon, Jul 8, 2013 at 3:23:40 PM | dingohot
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
Quoting dingohot from 2013-07-03 21:20:25
The Repeating Detail Component isn't applicable in this case. Sorry, I should have been more specific about the scenario; I'm creating Detail Groups out of all the 2D elements in a building section, such as linework and other Detail Components like joists and structural steel sections. I'm then copying this Detail Group (in-place) into the wall sections. This is usefull because when something is modified in the building section Detail Group the wall section is updated automatically. The only problem with this is that after creating the Detail Group from the 2D elements it appears like I can no longer create array groups, which is annoying but not impossible to work around. I guess the simple question is whether or not you can array anything within a Detail Group.
Mon, Jul 8, 2013 at 3:31:42 PM | Array Groups within Detail Groups
Did you create the arrayed element seperate then add them to your group?
Mon, Jul 8, 2013 at 4:13:45 PM | WWHub
rastamanCP
rastamanCP Avatar
4 Stars: 4 Votes
Quoting WWHub from 2013-07-08 15:31:42
Yes, this is the only work-around I've found so far. I can create the initial Detail Group just fine. But if I need to add an Array Group afterwards then I am forced to create it outside of the Detail Group, then copy it (not cut) and paste it in place within the Detail Group. I still don't understand why nothing can be arrayed within a Detail Group.
Perhaps there's a better way to approach the initial goal, which was to have 2D elements in building and wall sections which update in both when modified.
Tue, Jul 9, 2013 at 7:34:32 AM | Array Groups within Detail Groups
I believe the problem is a process within Revit.  If you are in the group create process, how can you start the group process  again?  Remember, an array in itself is creating a group.
Attached detail groups missing from model groups...
Mon, Aug 17, 2009 at 8:11:10 AM
Detail Groups NOT DELETING!
Thu, Apr 2, 2009 at 4:03:47 PM
Groups and Phases
Thu, Jan 29, 2015 at 10:45:27 PM
Revit 2008 Groups
Tue, Apr 17, 2007 at 2:08:31 PM
RAC 2009 - detail groups and section detail blow-ups
Fri, Mar 26, 2010 at 8:50:53 AM
Page generation time: 2.4848
