Forums >> Revit Systems >> Tips & Tricks >> Different leader heads at the same time?
Mon, Jul 1, 2013 at 2:12:01 PM | Different leader heads at the same time?
kperkSTRC
In AutoCAD it was simple to use different types of leader heads at the same time, i.e. arrow and open dot.  Is there a way to have two different leader types attached to the same text?  Any way this can be done?  Revit 2012
Thanks!!
Mon, Jul 1, 2013 at 2:16:06 PM | Different leader heads at the same time?
No
Mon, Jul 1, 2013 at 2:21:01 PM | Different leader heads at the same time?
kperkSTRC
Any way this objective can be achieved?  Anything more elaborate than "No" would be nice!
Mon, Jul 1, 2013 at 2:25:57 PM | Different leader heads at the same time?
You don't say where you want this so we can best assume text.
Place a second piece of text with a character like a period? << Not a good idea
Create a special family << Better idea ... and what do you know.... there seems to be one in the downloads
Mon, Jul 1, 2013 at 2:43:17 PM | Different leader heads at the same time?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Since the leader is part of the text you can't have more than one type.  Create a blank generic annotation save it as something like LEADER and load it into your project.  Now you can insert it as a symbol and place just a leader and place it next to your text. Something like this http://www.revitcity.com/downloads.php?action=view&object_id=2280
Mon, Jul 1, 2013 at 3:05:38 PM | Different leader heads at the same time?
kperkSTRC
Thanks teafoe, works nicely!
Fri, Jul 12, 2013 at 12:06:29 PM | Different leader heads at the same time?
Johnzo142
We use 2 different text types with the only difference being the type of leader. Place your first text note with say, an arrow leader where you want it. Then simply copy that text and move it in any direction a specific distance (1'-0" straight up). Then change the text type to the one with the different leader type (open dot). Move it back to it's original position (1'-0" straight down).
Edited on: Fri, Jul 12, 2013 at 1:07:40 PM
LEADERS AND ARROW HEADS
Thu, Mar 16, 2006 at 9:11:23 PM
EDITING TEXT LEADER ARROWHEADS AND LINES
Thu, Aug 14, 2008 at 3:21:20 PM
Multiple Leader Text
Sun, Nov 18, 2007 at 12:33:40 PM
Room Tag Leader Arrowhead Problem
Thu, Jan 21, 2016 at 11:18:11 AM
Default text leader location - top right
Thu, Sep 12, 2013 at 8:53:40 AM
Page generation time: 0.8206
