Forums >> Revit Building >> Technical Support >> Texture Map Gets Messed up after cut. (revit 2013)
Fri, Jun 28, 2013 at 3:13:30 PM | Texture Map Gets Messed up after cut. (revit 2013)
jbw77
I have a metal roof (modeled in place sweep) with a rusted metal texture as soon as I cut out a shape from the roof object the texture chages mapping direction.   Has anyone else run into this issue and does anyone know the work around.  I think it may have to do with the voids orintation compared to the sweep, but I'm not postive.
Mon, Jul 1, 2013 at 9:10:10 AM | Texture Map Gets Messed up after cut. (revit 2013)
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I would have done that as sloped glazing and changed the material of the glazing and mullions to your rusted material.  I know that is not your question but if you try that and cuttout where you need I believe the material will stay oriented correctly.
Revit to 3D Max Texture map offset.
Thu, Oct 16, 2008 at 3:25:20 PM
MAP TEXTURE IMAGES TO ELEVATIONS AND FLOOR PLANS
Mon, Mar 5, 2007 at 2:39:54 PM
Texture Map Problems
Sun, Feb 25, 2007 at 7:56:31 PM
metal building question
Fri, Dec 20, 2013 at 8:39:28 PM
Texture Maps & Rendering
Fri, Nov 4, 2011 at 3:54:17 PM
Page generation time: 1.8952
