Forums >> Revit Structure >> Technical Support >> Trench Fill
Fri, Jun 28, 2013 at 11:02:28 AM | Trench Fill
akunkinga
What is the best way to show Trench Fill foundations
ie On one side of the building the Trench fill slopes from 1.8m below ground to 1.0m below ground, the others are all different slopes
Thanks
Fri, Jun 28, 2013 at 11:31:47 AM | Trench Fill
Do it as a foundation family.  After all, it is just a different material.
Fri, Jun 28, 2013 at 12:16:46 PM | Trench Fill
akunkinga
Sorry new to Revit , not sure what you mean.
Do I have to create a new foundation family or edit type of one of the existing ones. I f the latter how do I create a slope on the underside I thought I could only amend the width or a depth such as 200 to 500
Fri, Jun 28, 2013 at 12:46:53 PM | Trench Fill
I had assumed the slopes you were talking about were vertical.  But since they are the bottom, just do it as a wall and sketch the elevation to slope the bottom.  No time like now to learn about wall sketches.
Really the other question is why are you modeling this?  Obviously, you will never see this item and in sections, you can use a detail element.   If you need it for BIM, then that is a different issue .... but I doubt that you really need a model element here.
Sat, Jun 29, 2013 at 4:20:48 AM | Trench Fill
akunkinga
Thanks I will try that.
Yes for BIM tbh I am still learning how to use REVIT. I am providing the structural elements of a model for the Architect to link to his model.
Floor Trench
Sun, Dec 13, 2009 at 3:02:11 AM
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
Fill Region Not Showing
Wed, Aug 22, 2018 at 5:28:47 PM
Revit 2009 - Fill Patterns
Sun, Nov 21, 2010 at 9:17:43 AM
fill pattern and line style
Thu, May 5, 2005 at 6:25:07 PM
Page generation time: 0.1012
