Forums >> Revit Structure >> Technical Support >> work plane
Fri, Jun 28, 2013 at 9:00:25 AM | work plane
akunkinga
Hello
I am new to REVIT (used to autocad) and looking for a video or tutorial that explains work planes. When I am asked to choose a work plane what exactly does this mean?
Thanks
Fri, Jun 28, 2013 at 9:12:11 AM | work plane
Work planes are only required for 3D elements.  They can be actual work planes that you create in the model (while in a plan, section or elevation view), grids, levels and in some instances, flat plane surfaces of elements like walls, doors, roofs etc.
Plans are typically set to the work plane of the level they were created from but while in a plan view, you can select a different work plane if required.  Just be careful doing this.
Elevations and sections have no associated planes set.
Set roof or soffit on work plane?
Mon, Dec 2, 2013 at 12:57:49 PM
14
Work Plane Error
Thu, Nov 5, 2009 at 8:41:13 AM
get rid of current work plane and 3D snapping
Fri, Nov 10, 2006 at 3:26:52 AM
Orient a view perpendicular to a work plane
Thu, Dec 17, 2009 at 11:52:39 PM
Disassociating work plane
Thu, Apr 21, 2016 at 11:10:28 AM
Page generation time: 0.7186
