Forums >> Revit Building >> Technical Support >> Elevation View
Fri, Jun 28, 2013 at 1:28:55 AM | Elevation View
cw202t
Windows in elevation are not showing detail only an arrow indicting slide direction. I've spent hours trying to solve this this. Attached an image
Fri, Jun 28, 2013 at 5:35:41 AM | Elevation View
4 Stars: 205 Votes
Change the view to "fine mode", if this not work you'll have to edit that window family and add the detail you want.
Fri, Jun 28, 2013 at 7:45:35 AM | Elevation View
Make sure your view depth includes the whole window.
Fri, Jun 28, 2013 at 8:58:14 AM | Elevation View
cw202t
Thank you so much - I was able to control it in the family editor under visibility settings.
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Making view titles reference each elevation
Mon, Oct 21, 2013 at 7:30:20 AM
ELEVATION CALLOUT DOESN'T SHOW UP IN DETAIL VIEW
Mon, Jul 29, 2013 at 4:50:17 PM
Transfer Elevation View to a New Project
Fri, Jun 10, 2011 at 7:36:27 PM
Changing Elevation Parent View
Tue, Nov 9, 2010 at 4:35:05 PM
Page generation time: 7.5537
