Forums >> Revit Building >> Technical Support >> Room area + window area
Thu, Jun 27, 2013 at 7:59:27 AM | Room area + window area
tysker
4.5 Stars: 2 Votes
Hi,
I've been dealing with this problem for a while now.
When i want to make room tag the area is only from wall to wall.
How can i get Revit to add the areal of the window too?
See the picture.
Thu, Jun 27, 2013 at 8:49:30 AM | Room area + window area
How did you describe your room boundaries?  You can use room bounding elements or room boundry lines - your choice.
Thu, Jun 27, 2013 at 5:51:39 PM | Room area + window area
narenvangamudi
REVIT should automatically detect the highlighted area in red, but it depends on how you modeled that part? It seems like something is not allowing/blocking that area to be included in the area function. Is that a wall or something else. Even if it's a wall, you can untick the room bounding option. See if that helps.
Room/Area report
Tue, Mar 3, 2015 at 12:58:57 AM
Room tags with area - area not showing up!
Thu, Aug 16, 2007 at 6:54:26 PM
room area calculations
Tue, Nov 4, 2008 at 3:48:50 PM
changing the scale of my room and area tags with the scale of my area plan.
Fri, Oct 22, 2010 at 10:38:38 AM
Thu, Jan 15, 2009 at 5:51:20 AM
Page generation time: 0.3563
