19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Walls' projection lines - how to turn them off?
Dear experts!
Could anyone help me with my problem:
on the elevation views, where the 1st floor wall meets the 2nd floor wall, there are walls' projection horizontal lines which separate these walls (their outlines).
But the City standards require not to show any lines at this place at all.
How can I fix this?
The same time i will need to have walls' vertical lines - at corners and some walls' ends.
Thank you.
If they are the same material on the same plane, then simply join the walls and the lines should go away.
Otherwise, use your linework tool with invisible line.
thank you for giving me a hope.
I used linework, but it is a long way, especially if there are many lines of other objects behind the needed ones.
But why my walls do not "glue" together vertically, as they do it horizontally?
Thank you.
projection vs. cut lines |
Mon, Oct 31, 2005 at 2:29:38 PM
why my projection lines overlap cut lines. |
Tue, Apr 10, 2018 at 7:41:07 PM
Toggle cut and projection lines |
Tue, Mar 6, 2012 at 6:57:56 AM
Projection Lines - Too Many Lines With Curves |
Tue, Jun 3, 2008 at 7:32:05 AM
Visibility Projection and Cut lines. |
Wed, Nov 5, 2014 at 1:55:03 PM
