Forums >> Revit Structure >> Technical Support >> Hide Lines from Void Solid
Wed, Jun 26, 2013 at 11:54:45 AM | Hide Lines from Void Solid
CHAsports
Hi, I made an opening in my roof using a void solid and now I need to hide the lines that show up underneath the roof (at the void). I attached a PDF. Does anyone have any ideas? Thanks.
Wed, Jun 26, 2013 at 12:28:04 PM | Hide Lines from Void Solid
A void is not a solid ....
There is no way for us to know what those lines are.  They could be where a solid edge is formed by a void cut but it isn't a void.
When you select an in-place void, its lines will show but only when selected.
Wed, Jun 26, 2013 at 12:39:28 PM | Hide Lines from Void Solid
CHAsports
I meant a "void extrusion" not solid. I just selected it so it would highlight where it was since in the attached PDF it's a little harder to see... but I can still see the lines when nothing is selected. Is there any way to get rid of those lines? They are part of the roof (where the void extrusion cut it).
Wed, Jun 26, 2013 at 12:59:08 PM | Hide Lines from Void Solid
If you can still see those lines, it is because a solid is being cut by the void and those edges are formed.  If the void sould not be cutting that solid, then fix that.
Wed, Jun 26, 2013 at 3:25:48 PM | Hide Lines from Void Solid
coreed
coreed Avatar
4 Stars: 16 Votes
That's because your void is cutting at the inside face of your arched roof. What your are seeing is the lines where the hip roof is being cut. Make your void a little larger that the inside diameter of the arch roof and these lines will not be seen.
Edited on: Wed, Jun 26, 2013 at 3:28:09 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Jun 26, 2013 at 3:42:24 PM | Hide Lines from Void Solid
CHAsports
Thanks coreed! It worked!
Void Masses
Fri, Oct 3, 2008 at 4:11:06 PM
Creating Solid and Void Extrusions
Thu, Jun 1, 2006 at 10:08:08 AM
void extrusion not cutting solid extrusion
Fri, Oct 10, 2008 at 3:47:43 PM
void behind solid object as dashed line
Wed, Dec 5, 2007 at 8:01:33 AM
Structural Deck Floor : What are these lines? How to hide them?
Wed, Feb 17, 2016 at 2:59:34 PM
Page generation time: 1.3599
