Forums >> Revit Building >> Technical Support >> 2013 Revit Arch - Control wall fill pattern in fine detail mode
Tue, Jun 25, 2013 at 10:19:20 AM | 2013 Revit Arch - Control wall fill pattern in fine detail mode
robp72
Hi! How do you control the wall fill pattern in fine detail mode. I see how to do it in coarse scale fill pattern but cant get the "hatch" pattern out of the fine detail mode. I am trying to show existing walls as simple two line walls and the new walls with the hatch pattern to represent CMU or block.
Thanks for your help.
Rob
Tue, Jun 25, 2013 at 11:09:35 AM | 2013 Revit Arch - Control wall fill pattern in fine detail mode
Wall fill patterns for fine walls are controlled by the material cut pattern.
Wed, Jun 26, 2013 at 8:20:58 AM | 2013 Revit Arch - Control wall fill pattern in fine detail mode
robp72
WWHub,
Thanks! I will take a look.
Take care,
Rob
Wall assembly layers not showing in fine detail - Revit 2015
Wed, Nov 19, 2014 at 12:16:01 PM
Revit 9.1 Detail compontent fill pattern orientation
Tue, Jan 14, 2014 at 4:18:30 PM
Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols
Mon, Jul 30, 2012 at 7:12:54 AM
Rotating Fill Patterns
Mon, Jan 28, 2013 at 8:34:03 AM
Revit 2013 text in coarse scale fill patterns
Mon, Feb 11, 2013 at 7:27:59 AM
Page generation time: 5.0549
